  1. Does it just change the GOP structure, throw away "I" frames?
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    As far as I know: standard it changes the GOP structure, but it does not throw away the I frames. If I recall correctly it throws away the P frames.
    I have read somewhere that when "Deep analysis" is used, the bitrate is lowered, by the percentage the movie is shrinked.
    The Dutchman
    Mar 2003
    Uranus
    It works very well
    It works by reducing the number of binary digits in the
    numbers used to represent the video data.
    If you have a 6 bit number it can describe 64 different levels.
    If you change it to 5 , it can only represent 32 different levels ,
    hence the reduction in quality....and more than 15% reduction in size.
