It is also worth pointing out that unless you decrypt the disc, you need to put the original DVD into your drive in order to play the files on your hard drive. Hence the need for a program like DVDDecrypter.
Results 31 to 33 of 33
Does that actually work ?Originally Posted by Nilfennasion
Say I have copied the files off an encrypted DVD to my Hard Drive in Windows Explorer. I double-click VTS_01_1.VOB on my hard drive. Are you saying that DVD Playback software is hard-coded to check all optical drives for the encryption keys ? I'm thinking of the case where you have a DVD-ROM and a burner. It would need to check both (ie. all optical drives) for your statement to be true.
I would have thought that the CSS keys are retrieved from the same source drive as the IFOs, BUPs and VOBs. I'm open to persuasion though
If in doubt, Google it.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
The NTFS problem again
By Kardi in forum DVD & Blu-ray PlayersReplies: 6Last Post: 22nd Jan 2010, 11:21 -
FAT to NTFS
By hardy in forum ComputerReplies: 13Last Post: 24th Jun 2009, 16:24 -
DVD player w/USB NTFS format?
By usaRaydar in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Nov 2007, 15:12 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59
