i borrowed Fist of Legend and it plays fine on my
DVD player but when i put CD1 into the cd-rom and try to
extract it to mpeg there isn't any dat file in the Mpegav
folder or any other folder
can someone please help me
any help at all is much appreciated
thank you
And if it's a DVD you borrowed, you have to put it in a DVD-ROM drive, not just a CD-ROM drive.
@mikewg
CD1 is a vcd(format 1.0)
@OH
i've also tried checking the properties of the folder but
still says 0kb
properties for the entire CD1 is approx.550Mb so something is there but i can't see anything -
The VCD probably doesn't have anything written to its ISO filesystem.
A VCD doesn't actually need to filesystem to play on a stand-alone player so that is why it still works.
To extract it, you can try the following:
Use CDRWin to create a CUE/BIN image of the VCD onto your HDD. Then use VCDXRIP (one of the programs in VCDImager) to extract all the stuff from the CUE/BIN image.
You may be able to use VCDGear on the CUE/BIN image as well.
Regards.
Michael Tam
w: Morsels of Evidence
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 9Last Post: 27th Jul 2015, 09:39 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 07:50 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 01:30 -
Do Divx dvd players play dat files?
By neo76 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Oct 2008, 22:27 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 08:03
