Hi all,
I'm a newbie in DV capturing/editing. I just finished editing my first home video using pinnacle studio 8. I've used studio's option burn movie to disc both as VCD & SVCD. It has crated a disc and it is playing with PowerDVD on my PC, but it won't play on my Cybercom DVD player.
I know my DVD player is capable of playing VCDs & SVCDs and it can also read CD-R. Do you think authoring with some other program will help? Any suggestions?
Thanks, Uros.
I suppose it wouldn't hurt if you used another program to author such as the freeware version of VCDEasy or even Nero, which has it's own SVCD template. Just to be safe you probably shouldn't create any menus. You'll have to rip the mpeg from your SVCD disc with ISOBuster in order to use it in either of the two programs I mentioned.
Just a thought. Someone else might have a better suggestion.
Why Won't it Play on my DVD Player?
By mreccentric in forum DVD & Blu-ray PlayersReplies: 17Last Post: 16th Jul 2013, 09:59 -
DVD player won´t play converted .avi
By dexter30 in forum Video ConversionReplies: 4Last Post: 10th Dec 2010, 15:59 -
dvd won't play on player but will on computer
By bubbadss in forum Authoring (DVD)Replies: 9Last Post: 28th Apr 2010, 02:49 -
DVD player won't play movie
By justmehere in forum Video ConversionReplies: 5Last Post: 21st Apr 2008, 14:02 -
Stand alone player won't play DVD-R
By NHLroyrocks in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 16:53
