I have several mpeg2 svcd format and i need to upload to my webpage to share with others, the problem is the these files are large (1min= 15 MB)so i was wondering if i can convert to divx or any other format without having to lose the quality but of course making it of smaller size as possible ?
I appreciate any help
Give Dr. Divx a shot and experiment with different file sizes, but use a test clip. If you are experienced with encoding to divx or xvid, use Virtualdub MPEG2.
Thank you for the reply, this software helps a lot and just what i need but i was wondering if i can do a btach conversion as well
thanks -
I'll assume you are referring to Dr. Divx. The answer is yes, but you'll have set up each file seperately. Before clicking "encode" in stage three, check off "Defer job for batch encoding". This will take you to the job list. To set up another encode, click "single encode" in the lower left corner. Once all your jobs are added to the queue, select the first job and click start.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
