a choice between an internal drive and an external drive what would u select and why?
i am just asking to see opinons on external drives..
i already have three internal ones, and i might trade one and get a external cause three drives, two dvd +-r and one normal burner well i dunno might be to much and serial cable to the one drive seems like it's slowing my system down
what u guys think of external ones
I think an external drive is great- if you need another drive and don't have room for an internal one.
I have 4 internal drives- one dual DVD, 1 CD writer, 1 DVD ROM and 1 CD ROM. It might be too much if you don't have a big enough power supply, but I've never had any problems.
And why a serial cable? It would be much cheaper to get a controller card than an external drive. -
well my two different writters are hooked up on secondary ide
and two hard drives on primary
and my board has two serial connecters so i just use the convertor it came with from ide to serial hehe,
but the drive i wont have to pay it will be a warranty exchange at futureshop here in canada, the same drive
hp 420i but the external instead 420e both being a nec 2500 -
I imagine that the drive on the serial cable is pretty slow. You can pick up an ATA controller card for less than $40 (US). The last one I bought was off eBay- it cost $20 including postage.
Internal for me. An external would be just one more thing I could spill beer all over....
Internal vs. External ripping
By hardy in forum Newbie / General discussionsReplies: 9Last Post: 27th Jun 2009, 11:32 -
Can a pci esata card be both internal and external simultaneously?
By yoda313 in forum ComputerReplies: 9Last Post: 1st Dec 2008, 14:45 -
Use Internal Harddrive as External for ps3
By f-zer0 in forum ComputerReplies: 10Last Post: 10th Aug 2008, 17:33 -
External/Internal dVD-R dual layer burner
By SIRCOOKS in forum ComputerReplies: 6Last Post: 14th May 2008, 11:45 -
External x Internal HD
By fjmr in forum ComputerReplies: 7Last Post: 21st Oct 2007, 17:12
