Is there a way you can change tmpgenc temp dir location ??
Or does it use one...when encoding the video stops half way but it keeps encoding and wondering maybee if hd temp folder is running out of space if its pointing to my c: drive as default...
I don't think, that TMPG uses a temp directory when encoding the video. It use the temp dir for some audio procedures and probably for cut/ join too.
Go to option> enviromental setting> general> Folder setting.
not move the file tmp dir to upload folder
By velayudham in forum ffmpegX general discussionReplies: 2Last Post: 19th Jan 2012, 17:32 -
Speedfan and the various temp's ???
By blinky88 in forum ComputerReplies: 10Last Post: 19th Jun 2009, 12:37 -
ffmpeg / "ffpresets" dir (under Win32)..?
By Gew in forum Newbie / General discussionsReplies: 0Last Post: 19th Apr 2009, 16:40 -
CPU Temp
By Willy5157 in forum ComputerReplies: 4Last Post: 9th Feb 2008, 20:22 -
How to copy/convert hidden DVD with only "Track01.cda" in dir
By vincehal in forum Newbie / General discussionsReplies: 9Last Post: 8th Nov 2007, 06:21
