I've been really happy using dvdshrink to get my movies copied to dvd.
However some of the movies are just too large for 1 dvd. That is I really end up suffering from poor video quality. So I was wondering what I must do to use 2 or move dvd's to copy a video. Menues and all...
TIA.
B.
I think this tutorial might help you. Never used it personally, usually just delete extras and menus if I have to shrink the movie more than 80%.
http://www.dvdshrink.info/splitting-v2-3.php -
I have never and will never understand why people put the menu on DVDs that only have the main movie. But anyway, no biggie...Originally Posted by JustSomeGuy
I realise your situation is different, and I'm guessing you would like to split the main movie over two DVDs and then the extras on the 3rd ?
Many people here have said that Nero Recode 2 allows you to "replace" extras with a still image that tells the user to insert disc 2 or 3 to access that extra. You would need to split the main movie only over two discs while keeping menus and then blank out the main movie titleset while keeping all the extras and menus. Hopefully someone else is more familiar with Nero Recode 2 and can help you out.
I am confident that what you want to do is achievable.If in doubt, Google it.
Hard Disks
By Jomapil in forum ComputerReplies: 13Last Post: 20th Nov 2010, 10:29 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Problems Burning Movie Files onto blank Dvds-RW disks
By tealmarlin in forum Newbie / General discussionsReplies: 35Last Post: 1st Jan 2009, 12:18 -
Is there any way to decrypt the movie on that disks, so I would enjoy it?
By nazad in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2008, 00:40 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24
