Results 1 to 12 of 12
  1. For those that own one, what model HP Burner do you own and how do you like it? Have you experienced any problems with it? I'm not sure who has read my post about my HP CD-RW problem, but so that I don't repeat myslef too much, I bought a HP burner 16x10x40 and I can't get it to work with ANY other software except for the one that it came with (Record Now). Has anyone else experienced this? How did you get around it?
    Thanx
    Mario
  2. I have an older hp 9110i
    And even in windows xp I get all the compatibility by installing aspiinstall into it.
  3. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    My model is CD16ri. I 'think' that my problem might be common with HP burners that follow the same model number pattern as mine (ie CD12ri, CD16n etc). Perhaps HP burners that follow your model number pattern (ie 8230e, 9200i, 9510i ) are different. My burner, and perhaps all following my model number pattern, have 'buffer-under-run-prevention'. Maybe HP integrates something into the burner so that it can't work with other software. Perhaps that's the only way they can assure no buffer underrun.
    Please if anyone has any info on this, I would appreciate hearing it.
    Thank You
    Mario
  4. how do u get the model number.mine is a cd writer plus it came factory with my hp 8776c.i love it have had no problems using it with nero,clone,ez cd creator,ulead movie factory,etc.i have never had a buffer underrun with this
    and my vcd play in the sony sv360 which is rare.
  5. Ahh mine is a hp cd16r 16x10x40 and this sucker is awesome works with fireburner,nero,stomp,ez. and it uses fireburners built in bufferunder run options flawlessly does not work under cdrwin but no loss there cause fireburner does the trick.. oh and by the way i never even took the stock hp burning software outta the sleeve it sucks for sure
  6. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    Do you have a HP Desktop by any chance? If not, what in the world am I doing wrong/differently? Any suggestions?
  7. Member Dhruv's Avatar
    Aug 2001
    Australia
    I've got a externel HP 8203 writer and it works with all the burning software that I've tried and runs fine under Windows XP.
    I only dream in black & white...
    MSN: paschendale@gmail.com
  8. i have a 12x hp cd-rw drive, 9510i i believe.. its worked really fabulously for me.
  9. My works fine... It's not the best one, but it works with all the programs i use..
    It's the same one that came with my computer.
  10. I have a 9100i and it works great with everything, not only that there tech support is excellent, My burner stopped burning and I lost my receipt so the retailer wouldn't touch it. I phoned up tech support and tehy sent me a replacement drive within the week, they still haven't picked up the old one though , Just as a side note, I only ever made 2 coasters in the year I've owned it, both when trying to copy safedisk v2, which I subsequently learned a lot about
    <font size=-1>[ This Message was edited by: Shabubu on 2001-11-10 07:52:42 ]</font>
  11. I have a HP 8x4x32 cdwriter plus series 9100. It works great and with almost anything I've tried. (EZ CD CREATOR,CDRWIN,CLONECD,NTI CD MAKER,FIREBURNER,NERO burning rom,clicknburn).Draw backs (slow,doesn't overburn,no burn proof). I have a faster TDK velocd writer but I keep the hp in my system because It works with CDRWIN and the version of CloneCD i have which doesn't work with TDK burner
  12. and no i definately DO NOT have a hp system i have a homebuilt of course... what os you running and tell us you're exact error messages more info please
