It's not a major catastrophe, but can anyone tell me why the picture on the dubbed dvd looks like it bleeds sometimes ?? I recorded some tennis matches to my hard drive and then dubbed to dvd-r---- the picture is completely different, not as smooth as on my hard drive. What can I do to fix that![]()
Results 1 to 12 of 12
You can start using better media blanks since this is a reoccuring problem with using cheap media...
What media are you using? Try some Panasonic media for a test. What record speed did you use?
I use TDK dvd-r (2X). Where can I get Panasonic media??
I don't think I've ever seen it at Circuit City , Best Buy or anywhere else
TDK media is usually pretty good, and I've never had a problem with it in my DMR-E80H. Of course, they could have changed, so trying another brand might be in order...
What mode are you using for dubbing (as opposed to recording to the HDD)?
Do regular (commercial) DVD's have any playback issues?
What does it do when you try recording to DVD-RAM and playing it back? How does the quality look? -
I've never tried dubbing to dvd ram. I record in XP mode, and dub in EP since the matches are long.
Are you high speed dubbing with good media then it should look the same as it was on the hard drive.
That's your problem.I record in XP mode, and dub in EP since the matches are long.
EP mode on the Panasonics is 352x240 resolution.
Then what mode do you suggest I record in?? I am a novice you know :P
I never use anything other than XP and SP mode for recording.
You're starting with an excellent quality recording on your HDD (XP mode) and reducing the quality substantially to get the longer times. This is the source of your problem. If you recorded to HDD at EP speed, you would see the same problem there.
For longer stuff, you can record at SP and get about 2 hours per DVD-R. If I need to go beyond 2 hours, I record to HDD and split the results onto two or more discs. For quality, XP is the way to go (but you only get 1 hour of video).
SD Panny Plasma Quality worry
By MAC007 in forum Newbie / General discussionsReplies: 11Last Post: 3rd Jan 2011, 14:08 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
panny lx3 movie
By charlietoosey in forum Newbie / General discussionsReplies: 2Last Post: 29th Nov 2008, 04:22 -
Pioneer 340 as replacement for Panny DMR-E80?
By LynnL in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Jun 2007, 13:04 -
Panasonic E80 hard drive crash
By csanders1962 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 25th May 2007, 17:57
