  1. Hey
    i just upgraded to FSOJ and its eating up my Ritek G04 DVD-R,
    i need to get FSOF. Can someone give me a link of the windows application not the bin. Do i need to downgrade my firmware or how can i get rid of FS0J, PLEASE HELP GUYS
  2. Hello,
    I got this off of liteon's website
    "NOTE !! Once the drive has been upgraded to new firmware , it can NOT changed back anymore."
    So it looks like you might have to wait for an update on the firmware and hope that will solve your problem. I have the same drive and the same firmware and have not had any problems with the memorex DVD-R DVD+R or the DVD+RW discs, or the Ritek +RW's, but I never tried the Ritek +R's or -R's.
    Hope that help's,
    Mike
    Nov 2003
    Midlothian,VA
    i don't know how to go back on lite on firmware but i have read that it can be done. try going to www.cdfreaks.com website and search thier forums. you should be able to find out how and also be able to get a copy of the firmware you are looking for.
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    go to this site and download FS0F
    http://dhc014.rpc1.org/indexOEM.htm#L
    check out the LITEON forum at cdfreaks.com, they have instructions on how to flash your drive.
    http://club.cdfreaks.com/forumdisplay.php?s=&daysprune=30&forumid=44
    I would suggest you upgrade your 411S to the 811S by using the ZEBRA MOD. Check the LITEON forum for more info and instructions hot to upgrade with the ZEBRA MOD. I upgraded mine and it burns RITEK G04 DVD-R much better using firmware for 811s HS0P. You would need to get the HSOP firmware from dave's site (the one I posted up above).
    for ZEBRA MOD go here:
    http://www.speedlabs.org/
    you would need to join the forum before you can download the ZEBRA MOD.
