I recorder show on my DishPVR, then captured to computer. There was a glitch in the playback from PVR at one point. By playing the show back in slow motion 1/15sec on the PVR I could get through the glitch and capture a second short avi with all frames intact. Just a lot of extra frames.
So to replace the glitch with good frames I need a way to extract from my slo-mo clip every 15th frame starting at a known frame number and make a new avi clip. I'm somewhat familiar with AVISynth and could do it with a long chain of Trim command (as far as I know you can't loop in AVISynth ?).
Does anyone know a better way, have a script that would do it easier? I also have access to Vegas 4.0 at work but didn't see any quick way to do it inside that. I will use Vegas to patch the glitch with the new frames.
you lost me with what you are trying to do there - but virtualdub has decimate built in ... decimate by nFrames
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Replace every 15th frame with 14th frame
By NBninja8 in forum RestorationReplies: 43Last Post: 23rd Aug 2011, 03:49 -
How to extract date from hd movie clip?
By slobadaca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 20th Dec 2010, 04:24 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53 -
How to extract an AVI clip from a ts video file?
By alegator in forum Video ConversionReplies: 5Last Post: 10th Mar 2008, 19:48
