It seems I like going around in circles – been trying different productions and options but still not confident in what I should use.
Tools I have: (all latest versions)
Adobe Premier
TMPGEnc Plus 2.5
TMPGEnc DVD Author 1.5
Nero suite
Question 1: What to do – Is it better to:
- export from Premier to a ‘.m2v’ file then into ‘TMPGEnc DVD Author 1.5’ to Author and burn DVD
- or
- export from Premier an AVI file bring it into ‘TMPGEnc Plus 2.5’ to create an .MPG file then into ‘TMPGEnc DVD Author 1.5’ to Author and burn DVD
Question 2
Does DVD authoring tools affect the quality of the movie. In other words would I get the same quality of DVD if I authored in ‘TMPGEnc DVD Author 1.5’ or ‘Nero’ suite
Thanks for ANY opinions
Randy
Originally Posted by sfrandys
I need to have a program that accepts an MPG2 with AC3.Thank You & Have a great Day! :)
reman -
Question 1. The fewer steps the better. If you feel that Premier puts out a good quality mpeg, then do so. If you are not happy with it's output as mpeg, outputting an avi (one conversion) then encoding in tmpgenc (second conversion) is not going to improve quality.
Question 2. NeroVision Express is akin to Tmpgenc DVD Author, with a few more bells and whistles. Still difficult (impossible?) to manipulate menus. A large collection of canned templates though.
Try DVDLab. It's well worth the investment.Cheers, Jim
My DVDLab Guides
Video CD/DVD Authoring Burning program Recommendation
By illyad in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2012, 09:05 -
Blu-ray authoring software recommendation request
By Bradskey in forum Authoring (Blu-ray)Replies: 5Last Post: 27th Mar 2011, 17:21 -
Authoring tools used in Hollywood
By sampalmer21 in forum Authoring (Blu-ray)Replies: 4Last Post: 9th Nov 2009, 15:38 -
AVS DVD Authoring tools
By jimlong in forum Authoring (DVD)Replies: 1Last Post: 13th Oct 2008, 21:13 -
Open Source authoring tools
By lmemsm in forum Authoring (Blu-ray)Replies: 2Last Post: 8th Jul 2008, 11:20
