Having trouble with 29fps videos now, it never ends.
I have a 29fps avi, and when i load it into TMPG to encode the video comes out fine with black borders of a few MM on each side, now when i use CCE to do the same thing there are huge borders several inches thick all around the picture, and this of course looks dreadful when played back.
is there someway to over come this using CCE?
thanks.
Results 1 to 10 of 10
I use WavWorks for this kind of audio conversion with great success. Fastest and simplest way there is. Has a 23.976 to 25 fps preset.
/Mats -
You probably have the DVD compliant option checked which makes it resize, in your case, to 720x480 by just adding black borders. In my opinion, you should never use the DVD compliant option for multiple reasons.
What is the resolution of your source avi? CCE doesn't allow resizing except with the abovementioned dvd compliant option, so you need to take care of that before loading it in CCE. The best way would be through avisynth but you could also frameserve through virtualdub or even TMPGenc for that matter, though this would be much slower. -
It won't accept it because now the resolution is not dvd compliant. Like I said, you have to do the resizing by frameserving to CCE. You can get a list of dvd compliant resolutions by clicking on the What IS DVD link to your left. You generally don't want to increase resolution if you can help it so with that 512x384 avi you would resize to either 352x480 or 352x240...neither of which are preferable, but there's no helping it with such an odd source as this.
Black borders all around video
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Oct 2010, 18:01 -
Need a program that adds black borders
By zubiri in forum Authoring (DVD)Replies: 2Last Post: 14th Sep 2010, 20:42 -
Cutting black borders
By HamishT in forum Authoring (DVD)Replies: 17Last Post: 4th Mar 2009, 18:53 -
Does anybody know how to convert 16:9 to 4:3 with black borders?
By tuanvn.2007 in forum Video ConversionReplies: 7Last Post: 20th Sep 2008, 03:13 -
Black Borders won't go away!!!
By mirandapanda in forum Newbie / General discussionsReplies: 6Last Post: 10th Sep 2008, 02:49
