Hi,
When I demux a DVD, a get the .mv2 file, and the .ac3 files.
I´m trying to reauthoring the DVD in Spruce DVD Maestro, but the audio files are out of sync.
The main movie have 1:18:22 and the audio file have 1:17:55.
When I compile this DVD, the audio track is not sync with the video.
How can I fix this problem??
Thankx
You could try the Time Warp function in Goldwave to change the time length of your audio file to match the m2v. Save the changed file as a wav and use an audio encoder to convert to ac3 or mp2.
If Goldwave can't open the ac3 then convert it to a wav or mp2 first with an audio encoder.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
