Yeah i'm trying to convert an avi to vcd and it gave me that problem. What should I do ?
Results 1 to 29 of 29
Is it configured to decode the 4cc of the movie in question? If it is than try disabling it.
Make sure FFDSHOW is disabled and try re-installing the xvid codec.
Well I tried disabling/enabling the xvid codec in ffdshow before, guess I'll try disabling ffdshow now.. how do u disable it anyways ? :S
You know what? Let's move past that for now andry something else. Open the avi in Virtualdub, go to the audio menu and select full processing mode, and go to file and select save wav. Use the wav file as the audio source in TMPGEnc, and obviously the avi as the video source.
A couple of more things you could try:
1. Frameserve with Virtualdub (you can find a guide if you click throught he link if you don't know how)
2. Raise the priority of the directshow multimedia file reader in TMPGEnc. Options>Environmental Settings>VFAPI Plugin -
mmm not sure what to do for the framserve I"m going to look that one up tomorrow , think i'm going to encode the audio to mp3 and see if that works.
acm error is caused because tmpgenc can't read the audio file that you're using. You may not have the proper audio codec installed.
try encoding just the video stream. you can demux the audio using another program.
Place a dot next to ES (elementary stream=>video only)
if tmpgenc adds a path for the audio, go ahead and delete the path so it is left blank. -
Once you click on the Virtualdub link you'll see "Guides for this tool" mid-way down the page. There's a guide for frameserving.Originally Posted by StoneColdWhat
That would have been my next suggestion. Just wanted to see if there was still a way to encode the audio and the video together. Still an excellent suggestion though. At least if the video is able to be encoded you can convert the wav to mp2 with FFMPEGgui and then mux with the video with MPEG Tools.Originally Posted by dafreak -
hehe, my bad teegee. didn't mean to steal your thread.That would have been my next suggestion. Just wanted to see if there was still a way to encode the audio and the video together. Still an excellent suggestion though. At least if the video is able to be encoded you can convert the wav to mp2 with FFMPEGgui and then mux with the video with MPEG Tools.
I appreciate the sentiment, but no such thing was done, my friend. I didn't take it like that at all. Besides, I would never presume to think that posting on a thread entitles me to ownership of it.Originally Posted by dafreak
StoneColdWhat
In order to convert an AC3 audio file to wav using virtual dub you need to install the AC3 ACM compressor which is available in the tools section. After you install it open virtual dub and choose audio>full processing mode. Then audio>compression>AC3 ACM compressor. Then file>save WAV. -
Yessss LaddyDaddy's way worked. Thx to all those who helped especially teegee420. Ok well.. one more minor problem I dled the new tmpgenc plus and I'm trying to svcd a 40-50 min vid with the templates that came with it and after the encode it turned out to be round 900 mb :S too big for a cd-r but when I used the templates for my older tmpgenc the size came out to 600mb ish.... why might this be and what solutions do you guys have for me..?
If you didn't have the AC3 ACM Decompressor, how were you able to create a 350mb wav file when I suggested you decompress to wav before? I assumed you already had it installed because you didn't indicate there was any problem when you made the wav file with Virtualdub.Originally Posted by StoneColdWhat
Glad you fixed the problem either way. I can't really help you on the new issue. -
I didn't had a problem when I created the wav with vdub before, I just saved the wav without decompressing...
Aw, that explains it. Happens to the best of us, my friend. I've done some incredibly stupid things since starting my forray in digital video. A fool is someone who does not learn from his mistakes. At least that's what I keep telling myself.
hah well I'll definately keep this in mind next time I encode another ac3 vid. Say.. how can tmpgenc open mpeg-2s ? I dled Sticky's mpeg-2 codec before but it messed up my powerdvd.
AVCHD - Converting video pass 1: Errorcode: 0x0401,Error occured
By time2innov8 in forum Authoring (Blu-ray)Replies: 10Last Post: 19th Jan 2014, 15:20 -
How do you burn initialized DVD discs?
By Djard in forum MediaReplies: 6Last Post: 24th Jul 2011, 13:26 -
Error -1856: An Unknown error occured
By Tyler2000 in forum Software PlayingReplies: 2Last Post: 27th Oct 2010, 20:55 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
an unhandled exception has occured in your application
By thekingbeyond in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th Jun 2007, 17:54
