I burned some movies from divx to DVD with TMPGenc but when I try playing them through my DVD player there`s no surround sound, I have to use the tv sound instead.
What am I doing wrong![]()
Results 1 to 9 of 9
Your Divx originals may only contain a 2 channel audio. How do they play on your PC with a 5:1 sound system?
No DVD can withstand the power of DVDShrink along with AnyDVD! -
GuestGuest
Do you mean there is no sound at all or that you dont get the surround sound effects. Do you have a home theater? What do you mean by tv sound? Will it only play thru the tv's speakers?
I`v got a home theatre and no sound comes from the surround speakers, I have use tv speakers. If I put an original in there`s no problem, just the ones I made. They play ok on my pc.
do u have optical setup on your amp? might be the frequency its encoded in. i know my amp works fine with the rca's even on vcd's, but has probs with probs with optical connection. try switching your amp(reciever, whatever) to annolog connection.
Also, when you do the transcoding of your video make sure you create true stereo (2 ch) audio and not "Joint Stereo". "Joint Stereo" tends to loose the phasing information required to produce the rear audio in a dolby surround sound mix.
GuestGuestOriginally Posted by jazper
I just tried an older film I made, disc 1 was ok but disc 2 has no surround like the others, so something must have changed.
I only used stereo in the audio settings.
No sound comes from any of the speakers. I don`t know about the connections, I did`nt set it up. -
Surround Sound in Movies
By therock003 in forum AudioReplies: 36Last Post: 1st Jun 2012, 05:50 -
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Lg ht 355sd surround sound
By byrnech in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Oct 2011, 05:08 -
Need Help Encoding: Surround Sound Goes Away
By antiwebbite in forum AudioReplies: 3Last Post: 9th Jun 2010, 18:48 -
Problem with surround sound. Works why Im playing the TV but not with a DVD
By marionr26 in forum AudioReplies: 3Last Post: 15th Feb 2010, 17:28
