I am able to copy dvds to my HD fine. They burn good but occasionly i get some after being burnt that freeze, skip chapters, revert back to title screen or just stop altogether when i a standalone player
Anyone got ideas on why some work perfect and some are getting these problems. i'm getting sick of the coasters lol
i'm using dvd decrypter and clonedvd
It would help if you could give more details:
Have you eliminated Media as a possible cause ? try different brands ?
You could try burning slower (if you are burning at max speed). You could try different software, e.g. DVD Decrypter->DVD shrink->Imgtool->DVD Decrypter (Burn). all free. You can also try the img from Imgtool on your PC DVD player.
Are the films that have problems longer films needing more compression?
DVD-R,RVD-RW, have you checked the compatibility of your player to the left ?
Try some of the above, should just be a process of elimination. -
Low quality media? My impression of high quality (hence expensive) media is that the average disc quality is higher. El Cheapo discs might individually equal a hi Q disc, but on the average they don't. Cheap discs: 1 coaster out of ten, expensive media 1 coaster out of 100. (When I worked in the blank CD business, the brand names used to say that this was the diff between their (more expensive) discs and bulk unbranded blanks. I think the same goes for blank DVD)
/Mats
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
