I copied a golf tournament using microsoft media center and I want to retain a 30 second clip from the broadcast. Any tips on how to do that? I have Adobe Premere. Also, if I wanted to burn the whole 13 Gig i am not sure how to break that up on to several 4.6 GB DVDs. Thanks for the help.
Hi hindermi,
I don't know microsoft media center, so apologies if this is an obvious question - what file format did it save the footage to? AVI? MPEG?
If it was AVI, check out VirtualDub (freeware) - you can set a start and end point (your 30 secs) and then save that to a new AVI.
If it's MPEG - Womble MPEG-VCR might be able to do the job. I've never used it, but have read many times people saying it's good for editing MPEGs.
If it's AVI, there's a good chance that you could encode it to MPEG at a decent bitrate to get it onto one DVD. The source may come in to play here - was it analog TV, digital TV etc.?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
New Media center file .WTV format problem with Silicon Dust Cable Card PVR
By torrentlord in forum DVB / IPTVReplies: 3Last Post: 18th Sep 2011, 00:08 -
Windows Media Center File Too Large
By GLSmyth in forum Authoring (DVD)Replies: 4Last Post: 1st May 2011, 00:27 -
Play blu ray m2ts file in Vista media center
By ultraman36 in forum Software PlayingReplies: 4Last Post: 10th May 2009, 05:41 -
Laptop DVD Burner suddenly only burns small portion of DVD
By hydrurga in forum DVD & Blu-ray WritersReplies: 9Last Post: 13th Feb 2008, 03:39 -
Vista Media Center & DVR-MS file playback is poor
By iukini in forum Media Center PC / MediaCentersReplies: 1Last Post: 16th Dec 2007, 05:11
