For some reason keep getting gop errors after converting avi/divx etc to vcd. ok till i use tmpgenc dvd author then i get the error message saying 'video gop is too long'. I know theres loads of posts about gops on here but i just dont get it. in simple terms what is a gop and how can i sort this out and still use tmpgenc and tmpgenc dvd aurthor. sure i'm getting this error more since i got a newer version of tmpgenc dvd author.using 1.5.15.49 and 2.5 of tmpgenc.
It might be good if you tell us exactly how you converted
your AVI to MPEG , and with what program.
GOP is Group of Pictures. It starts with a complete frame , and
has several frames after that , based on differences from the
start frame. DVD specifications have a limit on how big they
can be , 18 for NTSC and 15 for PAL.
You set that in the encoder. You may have set it wrong -
i'm using tmpgenc to convert .use tmpgenc to merge two vcds together then use tmpgenc dvd author to
will u still get a perfect join putting into tda seperately ? where is the setting for gop sizes . cheers.
you have open GOPs says dvd lab
By sumeshkri in forum Video ConversionReplies: 1Last Post: 11th Jun 2010, 05:50 -
Upsides/downsides to open GOPs
By dadrab in forum Video ConversionReplies: 16Last Post: 6th Mar 2008, 21:53 -
Close GOPs
By Ar'ina in forum Authoring (DVD)Replies: 5Last Post: 23rd Dec 2007, 04:22 -
How to actually close "open GOPs" abd avoid warning with DVD Lab
By perfection in forum Authoring (DVD)Replies: 1Last Post: 1st Sep 2007, 00:42
