Hi, ok, finally got my setup up and running -
the gear:
Athlon 1400mhz
DVDRW
DVD ROm
512 mb ram
100gb hard drive
ELSA ERAZOR 3 card, VIVO
Using TMPEnc, Virt Dub, Virtual VCR, Power DVD, DVD LAb, and a whole lot of other programs in various combinations, been trying to capture halfway decent quality analogue VCR stuff, do put onto DVD. I know obviously due to the basic nature of the source it`s not going to be great quality, but when trying to capture at 720 x 560, or whatever it was, it either freezes up after 3 mins or so ( virtual VCR ( which is a shame because it captures the best!) ), or is very jerky ( virtual dub, etc) Been experimenting with various settings, etc, but to no avail!
So, is it something simple, like not enough RAM, or am I trying to capture at too high a setting even though same thing happens at 640x480...I don`t want to go too low, as I`ll lose whatever quality I have!
Or am I simply trying to achieve something with gear that isn`t powerful enough?
PL
Go to Lord Smurfs site :>
http://www.digitalfaq.com/capture/avivsmpeg.htm
It contains all the help you need. -
Hi Punchline,
I second a visit to LordSmurf's site.
The following link is worth a read (it also contains links to other threads):
https://www.videohelp.com/forum/viewtopic.php?t=219415&highlight=
You're kinda question has been asked quite a few times over the last few months, so there's probably plenty of stuff out there - just gotta find it!
The resolution of analogue VCR is only 352 x 240, so capturing lower than 640 x 480 isn't going to be a problem. Read up on this in the link I gave above (and the threads it then links to).
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Start sector question in GEAR PRO
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 22nd Nov 2009, 14:23 -
No refunds on broken gear
By Noahtuck in forum Off topicReplies: 2Last Post: 28th Feb 2009, 07:53 -
Newbie question: cannot view/capture older DV tapes
By sinbarambam in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 9th Jun 2008, 07:48 -
Stolen Gear
By newsphotog in forum Off topicReplies: 7Last Post: 5th May 2008, 08:42 -
Gear Head DVD+R?
By bevills1 in forum MediaReplies: 1Last Post: 8th Jul 2007, 12:56
