Hi,
I have a Hauppauge WinTV card which works fine but I always have some interferences.
It's diagonal red moving bars like if the are generated by a fan (so I disabled my chassis fan but I also have these lines).
It's not a bad antenna because I also have them when I connect my vcr to capture a tape.
Here is some screen captures:
Here is the main components of the card
Decoder: BT878
Tuner Model: Philips FI1216 MK2
What Can I do to suppress these lines ?
if you've got speakers or anything near the coaxal wire, move it. something might be interfereing with it. also, try replacing the wires connecting the TV to the computer.
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
TV Tuner card for use in Japan
By schwarznavy in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Jan 2009, 03:43 -
The Best USB Tv Tuner / Card around ?
By rock_king_my in forum Capturing and VCRReplies: 1Last Post: 16th Dec 2008, 22:44 -
tv tuner card help!
By johanc in forum Video Streaming DownloadingReplies: 2Last Post: 7th Dec 2008, 07:02 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
