does anyone know if you can place this format on a dvdr and play them on one of the new dvd/xvid/divx players? i know they will play on cdr fine.. i guess its possible that if it is possible it may only work on some..anyone have any luck with this? TIA
Just to make sure my question is clear.. i do not want to convert it to dvd format.. i want to have a bunch of xvid/divx movies on a dvdr
Works fine on my Ellion DixX player but the disks must me written in ISO format.
Yes there are players that can play DVD's with divx/xvid movies on them. I've read that some mpeg-4 capable players on play them on CD though. Try before you buy.
Well you can do a search on dvd players that will play divx/xvid on dvd-r, but i can tell you for certain that my PHILIPS 737 does this. Only thing is sometinmes xvid has some sync problems, dunno if that is a problem with the files or the player though...
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Divx\Xvid 2 DVDR
By eliqush in forum DVD RippingReplies: 9Last Post: 14th Jul 2009, 09:48 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 02:01 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
