Hi,
I have some old mpg files that I want to convert to xvid. The mpg files aren't the best quality, and I was wondering if there was a way to figure out which bitrate would be best to use. I don't want to encode them at too high of a bitrate, because that would increase the filesize without an increase of quality.
Sorry if this is a stupid question, but I haven't been able to find an answer to my question anywhere.
Terry
Thanks for the info, but now I have another problem. I downloaded the program, installed and got an error saying I needed the file MSSTDFMT.DLL. I had already installed the required runtimes, but I went ahead and reinstalled them. When that didn't work, I manually placed the previously mentioned .dll in my windows/system and windows/system32 directories with no luck. I even tried putting the filename in caps with the extension in lowercase, and vice versa. Nothing seems to work.'
I tried looking on the official homepage, but I can't read whatever language it is in, I thought russian, but babelfish won't translate it.
I noticed on this site, they said the only complaint was getting the program to install.
If anyone knows the secret to getting this prog to work, could you please let me know?
Terry -
I don't have a solution for you but you could use the DVDRhelp Bitrate Calculator in the meantime. Just select "Divx" as type, even though you're using Xvid. You'll also need to adjust the Xvid codec configuration for bitrate instead of video size.
I found a site that lets you download the .dll but I have no idea where you are supposed to put so try at your own risk.
http://www.dll-files.com/dllindex/dll-files.shtml?msstdfmt
AVCHD - figure this one out
By cloudxsoldier in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 3rd Aug 2011, 00:05 -
MediaInfo : what does this figure mean?
By Bonie81 in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2011, 23:22 -
New camera, trying to figure out how to use footage from it
By Nilfennasion in forum MacReplies: 1Last Post: 26th May 2009, 09:08 -
How to figure out the tempo of an mp3?
By sdsumike619 in forum AudioReplies: 2Last Post: 29th Mar 2009, 16:11 -
can't figure out Recording to pc
By deadmanrob in forum Newbie / General discussionsReplies: 6Last Post: 9th Sep 2008, 07:56
