hi peeps. quick question. i just upgraded one pc to another, and had to transfer everything over to the next. however now i have encountered a problem. i used to d.load a file, then extract the bin with from winrar,(i would actually see a bin file). now i try to do the same thing, but can not see the bin file. why is this, and how do i go about fixing this? also whenever i try to play a file on windows media player, i notice that i cant forward or reverse, however if i try to slide the bar forward, i then get.......parameter incorect, it then closes windows media player.
this is frustrating, because i never had this problem before. how do i fix this one?
thanks for any help out there.
Well what do you see? Are you sure you have all the rars, and are you using a current version of WinRAR to extract?Originally Posted by bodybuilders1
You probably had a software DVD player installed like Power DVD, or at the very least a better mpeg-2 decoder than the one your new machine has. Ditch WMP and try Media Player Classic. It has a built mpeg-2 decoder. I stopped using WMP years ago.Originally Posted by bodybuilders1 -
what i see is a -log file, which i then use isobuster on, and it does convert that into an mpeg file (which is what i want). but then i try to play, and i cant forward, and like i said, when i do try it gives me parameter incorect.
how do i get my bin image back? i am assuming that since i am not using isobuster on a bin image, but rather a -log file, that this is why this is happeneing (the parameter error that is).
what next? -
ohh, and this also happens with real player, it just simply does not let me forward. i might have thought that my file was corrupt, but this is happening with more than one different file.
thanks again!! -
I think you might need to disable "Hide Extensions For Known File Types" in Control Panel>Folder Options>View. Real Player is another crap player and I'm not surprised it gives you the same problem. As I said, you had a different mpeg-2 decoder on your old system. Either install a new one or use Media Player Classic or a software DVD player instead.
but why did they play with these programs on my other pc.
ohh and do you know why i am not getting my bin image, when extracting from winrar?
thanks again!! -
I don't know if you're not reading my posts or if you just don't like my answers. Either way I'm done here. Good luck.
what are u talkin about bro, my question is why no bin image?
thanks, and have a nice day!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Scan Audio file for Errors
By MegaTonTerror in forum AudioReplies: 1Last Post: 10th Oct 2009, 10:45 -
AC-3 file header errors?
By DRP in forum AudioReplies: 1Last Post: 28th Jun 2009, 00:24 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
Bin file
By anton225 in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 14:05 -
recycle bin errors
By piano632 in forum ComputerReplies: 11Last Post: 29th May 2007, 10:33
