hi everyone.
just wondering if anyone else has a....Matshita DVD-RAM UJ-810
if so, how do you copy? what programmes & media do you use?
please help because i'm wasting so many discs, & its starting to get really expensive.
I have a LF-E311 on my gateway. I use any burning program with it. Nero is what I've been using for several years and DVD-R as it does not burn to + disks. I've never used to burn to RAM disks though. Just what exactly is the nature of your problem? Give lots of detail!
No DVD can withstand the power of DVDShrink along with AnyDVD! -
firstly i used DVD Decrypter to rip my files onto my hard drive, but seemed to be having problems, so i now use VCD Galaxy DVDRip ComboPack. all seems to go well, so i then use Intervideo DVD Copy to copy the files onto a disc. on the setting, i apply the 'fit to one disc' method on all dvds that i try & copy.
although on every disc in which i have tried to copy onto states that it has 'succesfully copied' that isn't the case...1 or 2 have worked but the vast majority haven't. Although they look as though they've copied correctly on the underside of the disc, some of them dont load up on my dvd players. the ones that do load up, only play so much of the dvd then just freeze....am i doing something wrong???
Hardware
Mashita DVD-Ram UJ-810
Software
VCD Galaxy DVD Rip ComboPack
DVD Decrypter
InterVideo DVD Copy
Discs
Bulkpaq
Data Safe
(both dvd-r)
hopefully this makes some sort of sense to someone out there...it not just let me know & i'll try & go more n depth. -
What RAM media are you using? It sounds like a media write quality issue. I assume you are playing these in a DVD Player that supports DVD-RAM.
RG -
i'm using various media because i haven't found one yet which has continuosly worked for me.
DataSafe dvd-r
Bulqpak dvd-r.
is there a specific media type for DVD-RAM??
my dvd player does support RAM. coz some have copied correctly & play, whereas the large majority have failed to copy properly. -
The Matchita DVD-Ram will write to DVD-R media only. At least mine does. You do not need to use RAM media.
Get your self DVD-Shrink ( Free ) and Nero Burning Rom ( Payware )which DVD Shrink will use to directly burn after ripping/transcoding ( if shrinking to fit to one disk ) Before I bought an external Sony DVD-+RW drive I did all my backups that way. Granted, the Matchita unly burns at 1x but it NEVER failed to produce a good burn that would play on any of my 7 DVD players I presently own. Yes it is ridiculous that anybody should have that many machines but, I do this stuff also for business ( weddings- events etc... )as well. It does come in handy when I have to test whether a disk will or will not play on a lot of different makes of players. Any way give this a try as to me, it's the easiest and symplest way to back up a DVD so far. No need to use a decrypter ( except for some problem disks ) as Shrink will do that for you.No DVD can withstand the power of DVDShrink along with AnyDVD!
Matshita DVD Ram UJ851s not recognizing blanc dvd
By ezradallas in forum ComputerReplies: 7Last Post: 12th Mar 2010, 12:50 -
Help Malata DVP-810 free region
By DiegoC in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Oct 2009, 10:24 -
Problems burning DVD+R DL with Matshita UJ-850S
By Pablo2k1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th Jan 2009, 11:06 -
SolveigMM Video Splitter 2.1.810.30 Update
By DmitryV in forum Latest Video NewsReplies: 0Last Post: 30th Oct 2008, 08:19 -
matshita dvd ram uj 840s
By skaterboii in forum DVD RippingReplies: 3Last Post: 16th Jul 2007, 05:11
