Get the latest version 1..0.0.10 here:
http://www.posunplugged.com/jsoto/
A GREAT GUIDE for VOB Blanker here:
http://www.users.totalise.co.uk/~yyyyyy/vob_blanker/vob_blanker.html
"In order to fit a movie onto a blank DVD, people often do a main-movie only backup using DVD Shrink. This is a good way to minimize the compression needed, or can often remove the need to compress at all. But once re-authored, there will be no menus and the movie will start to play as soon as it's put into the DVD player. This is fine, but you might want to keep the menus, as many people like to use the chapter menu. You might also want to keep just one of the extras, but not the others.
This is what VOB Blanker does. But rather than remove the extras, which would mess up the structure of the DVD, it replaces them with a small blank VOB."
Mac version of VLC is less functional than the Windows and Linux version
By HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 03:48 -
vob blanker took away 'skip' feature
By m-man in forum Newbie / General discussionsReplies: 0Last Post: 14th Feb 2008, 23:07 -
Please Help-2 Split DVD 5's back together onto DVD 9 w/vob blanker, pgcedit
By ashoun in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 07:34 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 16:00 -
titleset blanker w vob 'viewer' ?
By gazix in forum EditingReplies: 4Last Post: 2nd Aug 2007, 12:19
