Hi,
I have a 4.2 GB Mpeg that i want to put on a dvd. I have the Cyberlink Power Director Pro that seems pretty easy to use but when i go to select the mpeg that i want on the disc it says that its too big for the disc. In fact another mpeg that's only 1.4 GB (38 minutes) shows up as being 3 GB! Is there any way that i can compress the mpeg or lessen the quality of it so that it will all fit on the DVD. Anyway i don't understand why an mpeg capured from a video player should suddenly be so large just because its going on DVD. The quality can't be increased?
Thaks for the help,
Paudge
please give us more information about your mpg source. if it is dvd compliant it shouldn't be any bigger.
not sure what u mean. Have a TV-in on the PC and recorded it through Power Cinema. Saved as an mpeg and plays with windows media player. There is a recording quality setting in power cinema but i'm not sure which one it was set to when i recorded it. Is there someway i can find out. Have tried right click properties to no avail!
cheers,
paudge -
ok so what i figure now is that I captured the mpeg on the DVD standard setting which meant 5000 Kbps (720 X 576) capture rate. This was probably unnecessary (being a recording from TV) and a lower standard would still of produced the same quality of mpeg. So what i need to do now is reduce the Kbps of the capture. Can the Kbps be reduced without losing image quality? and if so how?
cheers,
paudge -
4.2 gb should fit on a dvd. use another dvd author tool that does not reencode like tmpgenc dvd author.
Power director surround sound
By werdna99 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Dec 2011, 14:33 -
Cyberlink Power Director does not recognize widescreen
By sektionschef in forum Video ConversionReplies: 4Last Post: 4th Aug 2009, 23:56 -
Cant get sound from recorded TV in Power Director 7
By tuiluvva in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2009, 05:11 -
Cyberlink Power Director Problem
By ada1984 in forum EditingReplies: 6Last Post: 17th Nov 2007, 11:50 -
Power Director 6 create disc problem (trouble
By tekton364 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jun 2007, 17:35
