I know this may seem a basic question and I have trawled the "How to" Sections of this forum but I have not been able to find a solution to my problem. Most tutorials cover coveting MPEG1/2 to DVD etc
So I'll explain what it is I want to do and want I have done so far and hopefully someone can guide me on my next step.
I have a Standalone DVD recorder on which I have copied episodes of a TV programme I have now ripped theses DVD's to my hard drive using smart ripper what I’d now like to do is put theses VTS/Vob files through TMPGE Author so that I can use the editing frames to delete the adverts
To do this do I need to first to convert to MPEG1? This being the case what software can I use
I now two folders with VTS files what is my next move
Many Thanks in advance Towbar
Murphy was an Optomist
After "Create New Project " click on Add DVD video, locate where the VIDEO_TS folder for that particular dvd you ripped is and click on it. TDA will then displayl the clips ( Movies ) that live in that folder. Select what you want and continue. TDA will recreate MPG2 files which you them re author. Do that with every Clip that was displayed one at a time. By the way most DVDs recorded on standalone recorders can just be copied to the HD without any ripping software. No protection you know! Just drag the floders to the desktop or wherever yoou want them to go.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
I use VobEdit to DEMUX the VOB files and Cuttermaran to edit the simple streams and then I use TMPGEnc DVD Author to re-author.
Hi tmaxwell2435 thanx for your post
I have tried to load Cutterman but it is telling me i need Net Framework 1.1.4322 when i try to find the right file from microsoft I fall flat on my face any suggestions there are so many Netframework files to tell the the truth i'm not sure which one i require I've tried three diffrent files still it won't load
Your cracefully towbar
Murphy was an Optomist -
Originally Posted by Towbar"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope"
DVD Shuffling Required
By JamieLee2k in forum Authoring (DVD)Replies: 1Last Post: 15th Apr 2012, 09:50 -
dvd information
By ht0160 in forum Authoring (DVD)Replies: 2Last Post: 11th May 2010, 14:40 -
Basic Edit from Subtitle Information
By none295 in forum EditingReplies: 1Last Post: 18th Mar 2010, 13:59 -
Authoring Information n Help Required
By dbanga in forum Authoring (DVD)Replies: 2Last Post: 30th Jun 2009, 13:13 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 13:13
