Hiya... i downloaded DVD-Lab Pro, trialware... now i have three clips... 45 min clips... i'm trying to set up a menu... things go fine... the menu is displayed on the TV after i compiled and burned it on a DVD+RW. But one thing is missing. When played with the simulator integrated in DVD-Lab, the simple text button where changing color as i was browsing in the menu page. But on my TV set, it wont change color... so if i push the down arrow down and down and up and down... i don't know where i am... so if i then push the ENTER button on my remote, something will play... but which one ? Then i discovered that the selection could be made with the "1", "2" or "3" button on the remote... that's just like with Nero, but that is NOT what i was expecting of such a 'ware like DVD-Lab PRO !
Could some wize guy help me here ?
Thx for any advice !
iterita joe
Do you have any motion menus?
IF so, did you include the button text prior to generating the motion menu?
A common error is people create a motion menu. Then after adding the motion menu (m2v) to the menu, they decide to add the buttons for linking etc. . The button become invisible but selectable if you cursor or press the numeric key on the remote.
The correct way is to add all attributes to the menu before creating the motion menu.-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
Huuum... thx chummy... maybe you are right... i did put all objects, texts, rectangles, links etc... but i had no idea that i had to render motion menu ! Then, afted i read ur reply, i revisited dvd-lab, and i just could not find it ! Where is this ? Under what menu item ?
Please help again !
iterita joe -
"nightmare of the silent buttons"
Sounds like an Italian giallo
Sorry but I don't use DVD-Lab and have nothing to offer.
I just had to make that comment :P
I'll go away now ...
dvd lab pro - text labels as buttons - problem
By pike8 in forum Authoring (DVD)Replies: 2Last Post: 21st Apr 2012, 06:03 -
DVD ripping nightmare
By julius02 in forum Authoring (DVD)Replies: 22Last Post: 17th Aug 2011, 16:02 -
DVD-Lab Pro 2, making shaped buttons from parts of menu background?
By bizzybody in forum Authoring (DVD)Replies: 0Last Post: 24th Dec 2008, 19:06 -
DVD-Lab Studio - Selection buttons/characters
By DVWannaB in forum Authoring (DVD)Replies: 2Last Post: 30th Jan 2008, 13:49 -
Dummy audio file in silent DVD?
By elkfir in forum Authoring (DVD)Replies: 4Last Post: 2nd Oct 2007, 23:24
