Hello Gurus, this is probably not the most appropriate forum but it seemed like a good place to start my search. I'm looking at purchasing a webcam but am confused if I should buy a USB2.0 connection or a Firewire connection. My PC has a firewire port and I connect to the Internet using Broadband. Any advice muchly appreciated.
Many thks
Results 1 to 17 of 17
Unless you have your heart set on a model that only connects via USB 2.0 you might as well get a firewire webcam. What are the reasons for your uncertainty? Just curious.
Research the capture cards first. Find the ones with good reviews that are external devices. Narrow your choices based on that process, then see what kind of connection you need.
Adding a type of hardware connection should be the least of your cost.
If you have a notebook computer that could be different.
You may want to take a minute and fill out the "computer profile" under you profile. It could help you get better responses. -
Hi whubbard,
I've been using firewire for a couple of years and never had a problem. I've not seen anyone else reporting any problems either.
I've not used USB2, though I have seen some reports of problems - might be worth a search to see if you can find what the cause(s) were.
My personal feeling would be to recommend firewire... But just an opinion.
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks for the reply and advice, i have upated my profile to include the PC specs.
My uncertainty comes from conflicting advice i've recieved from Computer Stores. One shop told me that firewire would be slower than USB 2.0. There doesn't appear to many firewire webcams on the market here in Australia. I've enquired with at least 10 stores about the Orange Micro IBot Pro but it appears to be like trying to find rocking horse poo.
Basically, if firewire is faster then that will be my preference.
Many thanks for any advice
Cheers -
You came to the right place to get good information.
I would not rely on any advice received from a computer store. -
These links might be of interest:Originally Posted by whubbard
USB2.0
http://www.pcworld.com/news/article/0,aid,68823,00.asp
http://www.intel.com/technology/usb/spec.htm
Firewire
http://www.pcworld.com/news/article/0,aid,111068,00.asp
http://www.pcworld.com/news/article/0,aid,108445,00.asp
For a webcam, either should be OK. My reference to problems (having re-read your post) was in connection with transferring from a DV cam.
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Firewire has better real world performance. Take a look at www.anandtech.com or www.tomshardware.com
Firewire has better protocol (both high- and low-level), uses less processing power (processor time) and it is far more elegant engineering
FW-webcam is likely to be better quality, since FW is considered by many people as "professional solution". Which is of course true, since it's good for professionals too. No-one thinks USB as "pro-solution" and that's likely to have impact on products using it (read cheap and poor quality, or at least worse compared to fw-products). -
Do you have a USB 2.0 Port?
As for a webcam, I think either would more than easily handle it.
My relative has a webcam that runs on USB 1.0.
I do like firewire better, and if it uses less resources in your computer then that's just even better. -
Whether Firewire is better than USB 2.0, I don't know. I was under the impression that USB 2.0 was faster than Firewire except for Firewire 800.
On paper USB2 is faster, but in practice, old Firewire still beats it.Originally Posted by teegee420
USB 1.0 = 12Mb/s
USB 2.0 = 480Mb/s
Firewire = 400Mb/s
Firewire800 = 800Mb/s
As Capmaster said, these are the specs that each technology is capable of. What it's capable of doing on paper, and what it does in real life are 2 different things. -
this il ALL nothing but about a creapy WEBCAM.....why would you use firewire for a WEBCAM ?!! can anybody tell me ? unless you want ot spend the extra money....
just use USB, don't matter if is usb or firewire, ypu will still get that crapy images, anyhow.....don't matter your webcam, all what it matter is the internet connection....and that is not as fast as your webcam.....
got it ???
Dont underestimate computer stores, i experienced once they refered to this site, would you rely on that?Originally Posted by ajc53
That would be some good advice.Originally Posted by thor300
And I am not saying you can’t get good specific advice, either. However, I would not go to a computer store and make a significant purchase without first doing additional research. Same with a car dealership, real estate agent, etc.
This is not the only site I use for product reviews. But in my opinion it is the best. And besides it can be entertaining.
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 21:32 -
will a USB2.0 Firewire Adapter work for me?
By J.Frost in forum Newbie / General discussionsReplies: 22Last Post: 21st Dec 2009, 17:20 -
Can I up from USB to USB2?
By jollyjohn in forum ComputerReplies: 16Last Post: 30th Aug 2008, 10:05 -
Firewire or usb2.0 for external drive media center recording? esata?
By yoda313 in forum Media Center PC / MediaCentersReplies: 29Last Post: 8th Aug 2008, 20:42 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19
