Hi
Iam using dvd2svcd to convert dvds to svcd or vcds. I would like to know how to set the bitrate so my 135 movie will split liek this
Disk 1 = 700 mb ( this is where i want to make change coz dvd2svcd outputs a 743 or 764 mb file in which i cant add a motion menu.)
Disk 2 = 740 mb
disk 3 = 740 mb
Results 1 to 10 of 10
Hi nirbhayn,
The filesize is a function of the length (in time) of the footage, and the bitrate.
As you're converting to SVCD or VCD, the bitrate is fixed as per the spec for these. This can be found under the "What Is" section at the top left of the page.
This only leaves you the time to adjust to get the filesize you want. Refer to the DVDRHelp Bitrate Calculator for working out the timings - probably "Advanced" mode will be better.
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Hi nirbhayn,
OK, from your original post, I'll assume you wanna make SVCDs as the quality is better than VCD. The facts:
Length: 135mins
Filesizes: 700mb + 740mb + 740mb = 2180mb
So, in the DVDRHelp Bitrate Calculator (or another of your choice, but the functionality might be different):
1. Click on "Advanced Mode"
2. In "Video Length" put: "0 hours 135mins" (from above)
3. In "Type" select "SVCD"
4. In "CDs" select 1 x "Custom"
5. In "Custom Size" enter 2180 (from above)
6. Select the "Audio Bitrate" that DVD2SVCD will be using - I've assumed the default for the bitrate calculator of 224kbps in this example.
This gives you a calculated bitrate of 1978kbps. However, this only takes the "MPEG/Author overhead = 42Mb" and "ISO = 5Mb" into account only once. This will be the same for each of your three discs.
So, you need to subtract double (2 extra discs, 3 in total) each of these figures from your total file size: 2180 - 2x(42 +5) = 2086.
Plug this back into the "Custom Size" field, and I believe this will provide the bitrate figure you need to use to get the filesizes you want - or it'll be pretty close.
If anyone spots a flaw, please correct me.
Carpe diem.
Hi
I get how to calculate but now im not sure how to enter theese values to get following results -
Hi nirbhayn,
Sorry - I'm not that familiar with DVD2SVCD. Try searching the forums or try to find a guide...
Maybe someone else can / will provide the answer...?
Sorry I couldn't help more. Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
You can't do it in dvd2svcd. You can specify the bitrate, spread over the number of disks, but you cannot get the first at 700mb and the next two at 740.
I would split the avi file into 3 parts, and THEN encode each separately at the desired bitrate to get the filesize you want.
The 135 minute movie, spread over 3 disks, would be 45 minutes each.
If you make the first one 40 minutes, to get 700mb, the bitrate is 2169.
The next two are going to be 47.5 minutes each, at 740mb, gives a bitrate of 1906.
Adjust up or down as you see fit. This also takes into consideration a 224khz audio file, 14mb authoring overhead but not 5mb ISO.Cheers, Jim
My DVDLab Guides -
so your saying that use programs like Dr DIvx to convert that movie 2 avi and then convert it to vcd in file size i want. but insted of converting it to avi what if i make a project in dvd2avi and then use the project file as the video source and the output audio file as my audio soruce, i have done this before but the quality is not as good as dvd2dvcd. do you think the option you suggested will give same quality as dvd2svcd.
To avoid yet another conversion, loss in quality, you could use dvd2avi's project. Quality should come more from bitrate, and less from the software used. My apologies for not reading carefully the first time, and mucking about with avi's.
I think your best option may be to have dvd2svcd encode the whole thing to one big mpeg, then split it in Womble (or something similar) to the sizes needed, and then author.Cheers, Jim
My DVDLab Guides
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Converting Dvds, Settings with bitrate
By Ekeus in forum Video ConversionReplies: 24Last Post: 22nd Mar 2010, 18:19 -
DV AVI -> H 264 (bitrate and other settings)
By xprezons in forum DVD RippingReplies: 13Last Post: 31st Aug 2009, 02:13 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Video Bitrate Settings
By bdr13278 in forum Authoring (DVD)Replies: 2Last Post: 4th Nov 2008, 12:34
