I've just got a new mobile phone that records video clips in .3gp format. Does anyone know how to convert this type of video to mpeg with sound?
thanks in advance
godammit!
which format could I convert it into so that I'd be able to email the video to people and they'd be able to easily watch it on something like WMP?
also how would I go about converting a dvd to .3gp? -
http://www.angelfire.com/pro/nokia3650_3/3gp_to_avi.html
the link to 3gpToRawAvi.zip doesn't work but you will find it if you search for it at www.google.com (second link).
i have no idea if it works. -
Thanks very much, I'll give it a go.
I'm also going to try and rip some short DVDs and convert the vobs to 3gp so i can watch them on the move! -
http://www.mpegable.com
MPEGABLE will encode to 3gp
its $19
they also have some high end encoders .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
3GP
By begeta50 in forum ffmpegX general discussionReplies: 3Last Post: 16th Aug 2009, 11:15 -
FFMPEG 3gp conversion
By diskontrol in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 03:50 -
3gp conversion problem
By nddcndndd in forum Portable VideoReplies: 5Last Post: 20th Oct 2007, 13:15 -
FFMPEG 3gp
By dizzy123 in forum EditingReplies: 3Last Post: 6th Sep 2007, 03:24 -
ffmpegx.... 3GP conversion= bad quality
By PIZZ in forum ffmpegX general discussionReplies: 1Last Post: 7th May 2007, 11:04
