I don't get this. When I use the new TMPGEnc DVD Author and author a DVD, I use the motion menu setting, and set the motion menus for 15 second intervals. When I author the DVD and check it by playing it in Power DVD, the motion menus work FLAWLESSLY. They play for the entire 15 seconds, then repeat over and over. When I BURN the files onto a DVD and play the DVD on my standalone, the motion menus are frozen. In other words, they are just pictures. They don't play at all. Now why is it that they work when I play it in Power DVD, but they are nothing more than pictures when I burn the files onto disc and play it in my standlone? Any help to FIX this would be appreciated, as I LOVE the way the motion menus look when I play then on Power DVD and I'd LIKE to see that same look when playing them in my standalone. It makes them look much morem professional!
it's your standalone player, i'd got the same problem with my old standalone player (not so old , 2003) and with my new standalone player the motion menus work. I don't know if there is a trick to make it work but I don't think so.
Some silent DVD menus won't work on Toshiba Blu-ray player
By denali in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 7th Feb 2012, 06:04 -
Does Tmpgenc Authoring works 4 support motion background menus?
By perfection in forum Authoring (DVD)Replies: 1Last Post: 10th Mar 2011, 02:35 -
Free Software for Motion Menus?
By thomasj in forum Newbie / General discussionsReplies: 5Last Post: 21st Nov 2008, 14:03 -
Motion Menus in DLP
By ckurowsk in forum Authoring (DVD)Replies: 8Last Post: 8th Sep 2008, 08:23 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11
