Using Virtualdub mpeg-2
MPG file info "Frame Size" is 480x480, 29.970 fps
when converting to DivX (tried both 4.12 and 5.11) wide screen is lost.
what I dont understand is how it can be wide screen in MPG, thougt 480x480 was not wide screen
anywhere I can configure to keep wide screen format??
It needs to be cropped and resized. Post a screen cap of a frame of the movie so we can try and figure out what aspect ratio is. Once that is determined you just need to resize to a resolution with the same aspect ratio. The black bars will need to be cropped too.
Tell you what, if you want to do things the quick way you can add the resize filter select 352x480, use Lanczos resize and re-encode as normal. It's just better to crop out the black bars so that the bitrate isn't wasted on empty space.
All worked out fine using Tegee's advice!
Additional question,
Having an DivX file with wrong ratio, square instead of wide screen. Is there any quality loss re-encoding to DivX again and cropping in the same way as with the mpg file? -
There's always going to be quality loss when re-encoding an already compressed file. You can attempt to keep things to a minimum by using a decent bitrate. I would characterize a good divx/xvid bitrate as being greater than 1000kbps.
You can do anything you want with your 480 vertical. Horizontal is irrelevant really in as much as your image is going to be stretched to fit the screen.Originally Posted by Olliver"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
Wide screen
By breeze9 in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2007, 23:31 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 04:37 -
converting wide screen to full screen. HELP!!
By arjunkkalra in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 13:41 -
wide screen
By ht0160 in forum Authoring (DVD)Replies: 16Last Post: 18th May 2007, 17:52
