i have a pentium 4, 2.0 gig processor computer...if i check the multi-threading in TMPEnc will it make my encoding faster?If your system has multiple processors, activate the option to Use multi-thread, otherwise TMPGEnc will only use the first CPU (if you only have one CPU, enabling multi-threading will usually make things slower, unless your system supports hyperthreading).
Results 1 to 11 of 11
Get a copy of cpu-z from here.
http://www.softpedia.com/public/scripts/downloadhero/13-5-23/
Run cpu-z.
Under the code name - either Northwood or Prescot.
Under processor selection - CPU #1 and CPU #2.
This will confirm that you have HT.
Another way to tell is your P4 CPU model must a "C" on it. E.g. P4 3.0C. -
tnx man ill try to do that...
but will it make my encoding faster if i check the multi-threading? -
If I remember correctly on another post here it stated that tmpgenc does not have ability to use dual processors which is what HT does. If you look under system details in control panel it may show as 2 processors.
i dowloaded cpu-zGet a copy of cpu-z from here.
Run cpu-z.
when i run the program, Under the code name - it is Northwood
but under processor selection - CPU #1 is grayed out
does this mean that my Pentium 4 2gig is not capable of multi-threading? -
you may have to enable HT in your biosOriginally Posted by d_unbeliever"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Yes. Not enabling SMP in any software that is capable of taking advantage of it could be considered a waste. If you leave TMPEnc using one CPU (on a HT machine) you would effectively be using only 50% of its processing power. (2 processors = 2x50%.) So enabling multi-threading will give a definite boost in performance to the degradation of the overall system performance.Originally Posted by d_unbeliever
Originally Posted by HardcorerussIn the end, it's up to the user to decide, based on circumstance and what your needs are. If you are comfortable leaving your machine running while you are away from it, then enable multi-threading. If you want to use it while encoding, then allowing only one CPU to encode (either HT or a real physical CPU) will give a boost to other tasks you want to perform.Originally Posted by TMPEnc Help File -
Sorry d_unbeliever but hyperthreading is only available on newer P4s with the 800MHz bus. 2.6GHz models and above, I believe.
I have nothing profound to say, so I'll just mention some things I really like (in no particular order): Tivos, Audis, Isuzu Troopers, Canon camcorders, Macs. -
I have a 2.4GHz 800FSB with HT and for further reference...Originally Posted by yamato72
Originally Posted by Intel -
thanks guys for the great info...i've learned a lot from you!!! keep on informing us newbies...
too bad my Pentium 2 processor did not make it
...oh well maybe i could afford to upgrade later
I am now accepting donations...
Xvid4psp and hyper threading.
By Raven2827 in forum Video ConversionReplies: 2Last Post: 23rd Jun 2010, 23:13 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 23:16 -
i7-920 Hyper-threading
By wulf109 in forum ComputerReplies: 14Last Post: 8th Apr 2009, 21:25 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 03:01 -
3.4 Pentium 4 or 935 Pentium D?
By DarrellS in forum ComputerReplies: 6Last Post: 12th Jan 2008, 00:58
