Currently with my computer (XP2100+ 512MB RAM...) it takes about 8 hrs to transcode or author video to be able to be burned to disk. What factors affect this performance rate, im guessing it is mostly the processor and the RAM that do alot of the work so would I need a faster processor and more RAM to cut the time a little bit? How long does it take whoever is reading this to do all of the transcoding work? Is this a fairly normal figure? Please ask for more specs if they are needed to determine whether or not they can speed the process up a little bit. Thanks...
RAM is probably third on the list behind CPU front side bus size.
Your capturing and editing in avi right? It takes a long time to convert that to mpg. The solution is to capture and edit in mpg. It is true that editing is best done in avi format but mpg editing has come a long way and in fact is probably all most people really need.
Here's a rough breakdown:
If want need:
1) Simple cut editing
2) Results in 2X time (in other words one hour of video takes one hour to capture and one hour to edit and author)
Then capture and edit in mpg format
If you want:
1) Editing with dissolves, transitions, overlays, and pinpoint accuracy
2) Results in 10X (One hour takes one hour to cap, two hours to edit, 7 hours to encode to mpg. Remember this is a rough estimate)
Then capture and edit in avi format -
I just capture video in mpeg format then use that NeroVision to transcode... Im new to this so i dont really do much editing.
Which CPU is better and faster overall?
By Stealth3si in forum ComputerReplies: 14Last Post: 3rd Apr 2012, 08:48 -
Faster DVD Authoring
By TheLaserdisc in forum Authoring (DVD)Replies: 9Last Post: 14th Dec 2008, 20:41 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 17:04 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 22:21 -
How to burn faster
By Finfarin in forum Authoring (DVD)Replies: 2Last Post: 2nd Jul 2007, 18:19
