When burning Video_TS files from a hard drive to a DVD I sometimes get a picture with no color and picture that "flips" as if the horizontal adjustment is slightly off. I've tried burning these particular files with Nero, DVDShrink, and Imgtool Burn, all with the same results. Other files of the same type burn correctly. Any help would be appreciated.
As you have treid various burning software..It would tend to point to a problem with the files you are starting with. But you dont say where, what or how you got to the Video_Ts folder stage its very hard to help you.Originally Posted by Guido22
Without some information its very hard to help....Not bothered by small problems...
Spend a night alone with a mosquito -
Is this the case of using NTSC template to burn PAL disc or the other way around (authoring issue)?
Burning to Hard Drive
By spacebiscuit in forum DVD RippingReplies: 8Last Post: 15th Dec 2011, 10:00 -
Having trouble burning from hard drive to DVD
By becassier in forum Authoring (VCD/SVCD)Replies: 5Last Post: 5th Nov 2008, 13:33 -
burning to my hard drive
By hawks770 in forum Newbie / General discussionsReplies: 2Last Post: 10th Aug 2008, 01:25 -
DVD Burning And Hard Drive Backing up..
By Mastablastacious in forum ComputerReplies: 15Last Post: 19th Jan 2008, 03:30 -
Trouble burning dvd from hard drive
By illyad in forum Authoring (DVD)Replies: 3Last Post: 10th Dec 2007, 12:20
