Hi all,
I've been facing lately an annoying problem;
When I import a DVD through "VOB Edit" or "DVD Decryptor" - both in Demux streams mode - and load the M2V file in Maestro, I ALWAYS get the error :
"Temporal References in GOP #...are out of sequence"....
If I import the same files through Ulead Movie Factory, and demux them later with TMPGENc, I get no errors......
Unfortunately, Ulead doesn't look to DVD's at the HDD, so I'd need either VOBEdit or Decrypter to work,
Does anyone know why the problem ?
I've tried WombleMPEG-VCR to fix the GOP's, but Maestro also refuses the "fixed" files.......
I've realized that other authoring sw's accept the stream....
Any guess on what Maestro means exactly and how to fix it ?
Thanks,
Zetti
