well i have a few dvds that r live concerts and the thing i wanted to do is get a few chapters off a few of them and put it in one dvdr.but the problem is i dont nkow how to do that. Is there a program that lets u extract just a few chapters? and also after i have everything wut do i use to put them all together? plz help. thx
Well...
First you need to rip the chapters you want from each DVD. Have a look at some of the guides under DVD Backup over on the left.
Then, you need to author them for a new DVD. Have a look at some of the guides under DVD Backup over on the left.
Then you need to burn to a blank DVD-+R. Have a look at some of the guides under DVD Backup over on the left.
If all else fails, have a look at some of the guides under DVD Backup over on the left.
If you get stuck, please post back with what you've done so far, what tools you are using and the specific thing you are stuck on.
Good luck!!
Editing audio on DVDs and BD
By tolson12390 in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2012, 14:49 -
Import home-burned DVDs to PC for simple editing?
By cookieJones in forum Capturing and VCRReplies: 16Last Post: 22nd Oct 2011, 21:46 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 16:03 -
Editing Nero made DVDs: DVDauthorgui? dvd lab pro? Gui4dvdauthor?
By KneeRow in forum Authoring (DVD)Replies: 31Last Post: 22nd Aug 2007, 01:41 -
Trouble editing DVDs
By t_burrito in forum EditingReplies: 6Last Post: 5th Aug 2007, 16:22
