Okay I'm sure this has been posted many times on the forums but the question still lies unaswered. I used besliced once to fix my ac3 file and the second time I used it all it does is pop-up notepad with the information on the first ac3 file it fixed. Now, everytime I drag'n drop a ac3 file into the window all it does is pop-up notepad. Does anyone know how to fix this problem? Thanks in advance =)
The further away I get from the things that I care about...
the less I care about how much further away I get... -
Nevermind, I did a forum search at doom9.org and found out what the problem was. The reason why people are getting the 'notepad pop-up' problem is becuase the ac3 file they are trying to fix has to be in the same directory or drive letter as the beslicedv0.2 folder. Lets say u have a ac3 file: needtobefixed.ac3 and its in directory d:\needto\befixed and your beslicedv0.2 folder is in c:\.....\desktop. When you run the besliced gui on drive c: and drag'n drop the ac3 file from drive d: you will get the notepad pop-up and vice versa, if your besliced gui is on drive d: and the ac3 file is on drive c:
thats a lot of shite right there.
got my besliced on my C drive,and all my mp3s,avis,etc on the D drive.
the latest i did was kill bill xvid uncut.
and all it did for me was stick the ac3fixed into the same folder on D but named the ac3 file killbillac3fixed.ac3.
so i cant see where peoples problems come for.
i got the same version,0.2.
heck..i just fixed wonderland,ac3 file,and thats fine too.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
