Results 1 to 12 of 12
  1. Can some one help me with this problem.
  2. Originally Posted by TGMan8681
    Sure that's an easy one
    Googled the answer for you
    Originally Posted by jagabo
    Dec 2002
    My Swamp
    Well . They do say use a title which best decribes your problem.
  4. Originally Posted by andyp1
    You're correct, I read too much into the problem....
    Googled correct answer this time
  5. Besides being Unsolveable, it must be Unexplainable also.
  6. Another case for the XP-files
    Dec 2002
    My Swamp
    I bet these two could solve it
  8. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    that's some real 90's hairstyling miss scully!
  9. Solution:
    Repost in Zen forum.
  10. Problem Solved:
    1 entry found for unsolvable.
    unsolvable
    adj : not easily solved; "an apparantly insolvable problem"; "public finance...had long presented problems unsolvable or at least unsolved"- C.L.Jones [syn: insolvable, unsoluble, unresolvable]
    U N S O L V A B L E
    Drop the 'e' and you'll have the correct spelling. Problem solved.
  11. Originally Posted by indolikaa
  12. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Try flea soap and brush hard!
