Is a dvd+r with bitsetting set to dvd-rom make a more player compatible disc than a dvd-r?
Anyone with practical experience?
no. dvd-rom is for your computer. Alot of times your stand-alone player will not play it.
A lot of DVD-ROM drives such as some made by Matshita require you to bitset your DVD+Rs or else they will not play them (they play DVD-Rs fine). Since my Optorite burner does not support bitsetting, I can not really verify this with experience. As for player compatibilty, I thought itcould help?
Yes bitsetting a DVDr + to DVD-ROM is the most compatible making it 98% compatible with all players (as I've seen it stated). A store bought movie is booktype = DVD-ROM, it's not just for computers, so the answer is yes (it may be the only way to get some older players to play a DVDr).
u are right. I went back and re-read the website. That only applies for dvd +r
As you can see, my original copy of 'Journey 2001' has been correctly identified as being a Pressed DVD adhering to the DVD-ROM media/book types...
EDIT: You're getting awfully fast with the 'Edit' button gitreel...
Samsung BD-P3600 DVD+R compatibility
By ynoldus in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Oct 2009, 15:55 -
DVD burner compatibility with Dell
By LWC in forum ComputerReplies: 14Last Post: 29th Nov 2008, 09:17 -
Check for DVD-compatibility
By otternase in forum Video ConversionReplies: 1Last Post: 29th Aug 2008, 04:58 -
dvd player with the best compatibility?
By JCWagener in forum DVD & Blu-ray PlayersReplies: 23Last Post: 16th Nov 2007, 22:17 -
Increasing DVD playback compatibility
By Truelight54 in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2007, 18:51
