This thing infected my computer on Saturday. I discovered it because my startup monitor reported that "avserv2.exe" was attempting to register itself to be run on the next start up. I started task manager(ctrl+alt+Del)and noticed a suspicious process running called "1234_up.exe". Downloaded the latest Norton virus definitions updated on 4/30/04 and the scan didn't find this sucker yet.Sasser worm spreading quickly
Monday, May 3, 2004 Posted: 2:48 PM EDT (1848 GMT)
(CNN) -- Computer security experts are dealing with at least four variants of a worm that is spreading quickly through Windows operating systems.
Known as SasserA, SasserB, SasserC and SasserD, the worm is targeting Windows 2000, Windows XP and Windows 2000 and 2003 servers. Other Windows systems, including Windows 95, 98 and ME, could be indirectly affected.
"It's pretty aggressive, and it's replicating very quickly," said Steven Sundermeier, a security expert at Central Command, a computer security company based in Medina, Ohio.
In a new, cunning twist by virus writers, an e-mail in wide circulation that purportedly offers a "fix" for the Sasser worm actually infects the user's computer with a different virulent worm, known as Netsky-AC.
"It really preys on paranoia about the Sasser worm," said Graham Cluley, senior technology consultant for the computer security firm Sophos.
"The very worst thing you can do is fall for this trick by clicking on the attached file," he said.
Cluley said there may be a connection between the creators of Sasser and Netsky. He says hidden in the code of Netsky-AC is a sarcastic message directed toward antivirus companies, claiming responsibility for both.
The Sophos spokesman said the Taiwanese Post Office, the train system in Sydney, Australia, and several banks in Scandinavia have been infected by the Sasser worm.
Spreading globally
While a computer virus requires some sort of human intervention to be launched, such as opening an e-mail, a worm takes off on its own. Sasser spreads through a Windows vulnerability known as LSASS, or Local Security Authority Subsystem Service.
Sasser scans random internet protocol addresses until it finds a vulnerable system. Then it copies itself into the Windows directory as an executable file, and is launched the next time the computer is booted.
Microsoft issued a patch, or fix, for this vulnerability last week. But in large corporate computer systems, these patches can have an impact on other internal systems. That means there's often much more to do than simply install the patch to both stop the worm and make sure other computer systems are not compromised.
Users could be affected without knowing it. One symptom is that the computer may restart every time the user tries to go online. As Sasser moves from machine to machine, it is also possible to remotely take over control of a user's computer. Sasser has been spreading globally since it was detected Friday.
Safeguards
While many businesses are being affected, Sasser has also hit home users, especially those with broadband connections.
Cluley says a personal firewall should be installed by home broadband users. There are many available and some can be downloaded free from the Internet.
He also suggests automating both patches from the Windows Web site and updates from antivirus companies. With hundreds of new worms and viruses created each month, these automated programs for PCs can be effective, Cluley said.
Sundermeier said a recent trend by virus writers has been to release threats late on Fridays or on weekends, when computer network security teams are not fully staffed. He said the Netsky and Bagle worms also were launched on weekends.
Both Sundermeier and technical experts at Panda Software, based in Bilbao, Spain, said it is labor intensive for technical teams to cleanse computers of the Sasser worm.
Unlike some types of security updates and service packs issued by Microsoft that can be applied to an entire network, many companies must correct this problem unit by unit. There is some nervousness about installing systemwide patches, for fear that they might impair something else on the network.
Sometimes the patches themselves are ineffective. In the past Microsoft has issued patches to fix patches, Cluley said.
I spent the better part of the weekend trying to remove this thing. I went to the windows folder and manually deleted avserv2.exe , 1234_up.exe in the system32 folder as well as a similarly named entry in the prefetch folder. Everytime I went online thereafter the same things showed up again, only "1234_up.exe" was renamed to something like "2337_up.exe". This happened several times. The worm also caused my system to shut down and restart.
Thankfully Norton updated their virus definitions today and the worm has been quarantined on my system. I also went to Windows Update and installed the latest security fixes. How I got the Sasser Worm in the first place is a little puzzling. According to a live CNN report I saw earlier you don't even have to open the infected e-mail for it to get on your PC.
Anyhow, to make a long story short, I would advise that people update their virus definitions and run a scan as soon as possible. I hope reading about my little ordeal helps at least a few of you.
Results 1 to 18 of 18
Yeah it's a worm not a email virus. Like blaster and welcha it auto replicates and spreads through security holes in the windows system and random IP addresses. Nowadays it's not just the noobs getting viruses. Just goes to show ya you should ALWAYS keep your windows updates up to date, as the security hole fix for this one was released by Microsoft in an update a month ago
Like backing up. It will take longer to clean up the mess than just backup stuff or put the required updates on your system. Kind of like the Fram Oil filer ad's. Pay me now or pay me later.
or just running a firewall and behind a hardware router/firewall and not using outlook and not opening suspect email. by doing that i've avoided all of the big scares and i've never used windows update.
and hech54 wondered why I got onto him about his refusal to use a firewall. :P
That is true, ususally a hardware router with proper NAT'ing will 99% of the time, protect a home computer, however the problem comes into play with laptops and ultra portable computers. Say you have a laptop and spend a couple nights in a hotel and unknowingly pickup one of these viruses, then plug the laptop into your home network or even the corporate network at your job, well there you go instant virus spreading behind the firewall. Now this may not apply to everybody, but there are enough people out there with laptops and *Cough* DMZ computers in a home network to be dangerous.
well my laptop would also have a firewall and up to date virus killer, so should be alright...
Originally Posted by CloudBurst
Originally Posted by tgpo- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Originally Posted by housepig
Code:int main() { printf ("You should laugh at this"); return 0; }
^^bit slow off the mark,eh.
the windows update was posted on about the 12th-14th of april2004.
that fixed the security breach.
updated OS,firewall,norton or eq,and it wouldnt be so much of a problem.
and as for using IE ,or mail,just connecting to enabling blueyonders net connection was enough for it to affect my mates pc(which ive just spent 2 hours repairing it,to get rid of shit like this.). -
Originally Posted by MeTaLgEaRsOoTy
Here's a follow up story:
Originally Posted by Yahoo Technology News -
I got som strange virus last summer and made a system restore of my computer to the way it was before it was infected. Nice feature in XP
Originally Posted by DVO
Damn spring break girls.
A quick trip to the doctor got my system restored to the way it was before I got infected. -
Sorry to drag this back on topic but -
Originally Posted by BBC
I hope they nail this ****** up.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
No let all of the service people and companies send him the bill to fix repair and cleanup his mess.
W2 blaster worm
By jyeh74 in forum Newbie / General discussionsReplies: 30Last Post: 16th Aug 2011, 13:23 -
.IVA file a real threat or not?
By hitman3000 in forum Newbie / General discussionsReplies: 0Last Post: 26th Jul 2008, 17:05 -
BBC reports Storm Worm attack on Blogger
By ahhaa in forum ComputerReplies: 0Last Post: 31st Aug 2007, 09:16 -
Newest empty threat from eBay sellers!
By lordsmurf in forum Off topicReplies: 3Last Post: 5th Aug 2007, 09:57 -
Windows Genuine (ahem) Advantage targeted by worm.
By AlecWest in forum ComputerReplies: 0Last Post: 8th May 2007, 19:47
