ok guys i'm sorry for this topic but i need a little help hope yall give it to me.'hey what do you want? i'm just a NOOB!
every guide about adding subs to a dvd starts with ripping it.
but i just want to make a dvd and download a sub and add it!! how do i do that?
Skip the ripping part of the tutorial, and jump right to the mux subs part?
Just a suggestionCheers, Jim
My DVDLab Guides -
dasnico,
Please don't post topics with titles like "please help" or "question" - a lot of people ignore them and it makes searching the forums difficult.
https://www.videohelp.com/forum/viewtopic.php?t=219535
Have you downloaded the subtitle file yet? I'm guessing not, because if you had then it would most likely be in a .sub file - using Subtitle Workshop in the way detailed in the guide above you will be able to add it. You obtain the same file by ripping the DVD.
Try to do it, and post back if you need further assistance. I wouldn't worry about it though, it shouldn't be too hard to do!
Hope this helps,
Cobra
(Edit - looks like you jumped in just before me, reboot!) -
or the easiest way
author with dvdauthorgui or dvd-lab pro , they both support srt subtitles. if you don't have the subs in that format convert with subtitle workshop.
you convert the video and audio as usual.
DXVA not playing??????plz help
By ansonjoy in forum Software PlayingReplies: 7Last Post: 9th Dec 2011, 08:35 -
want to create a boxset plz
By Lugs in forum EditingReplies: 5Last Post: 15th Nov 2011, 19:23 -
How to playback BluRay plz ?
By Cov(enant) in forum Blu-ray RippingReplies: 2Last Post: 16th Sep 2008, 17:44 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 10:12 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 17:52
