Results 1 to 13 of 13
  1. I have some music videos in vob format with the sound in LPCM format.
    I'd like to replace the LPCM Wave file to an AC3 file (stereo) to save space (I don't have a dvd burner so I can spare a few MB).
    So what's the best AC3 bitrate for converting a LPCM Wave to an AC3 (Dolby Stereo) with besweet ?
    Thanks.
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    In my opinion anything higher than 256kbps for 2.0 AC-3 encoding is a waste.
    In fact most commercial DVD releases use 192kbps for 2.0 AC-3 audio.
    However most stand alone DVD recorders use 256kbps for 2.0 AC-3 audio.
    I use 256kbps myself.
    The only time you would have to use a higher bitrate than 256kbps is if you had something more than a 2.0 source ... such as 5.1 AC-3 which should use 448kbps for best quality.
    - John "FulciLives" Coleman
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    yep -- what he says .. ditto
  4. i use 192 with high quality non music sources
    recently i've been using 448 just b/c the music videos i am doing are around 8,000 bitrate, 50 minutes long and have enough space to mux in a 448k file.
    i don't like having DVD less than 3.5GBs because of compatibility problems with some player
  5. Member teegee420's Avatar
    Dec 2003
    Southern California
    I'm pretty happy with 224kbps.
  6. I've tried several bitrates and it's great but i've also another question,
    Which is the best "endians": intel or motorola.
    I tried to make a dvd compliant ac3 file. My standalone is a Pioneer DV-454
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    motorola is correct for DVD's
    Nov 2003
    Houston, TX
    if u find besweet to be compicated, it doesn't get any easier than ffmpeg.
    josh
    [edit] with the gui anyways.
    Dec 2002
    My Swamp
    Am I missing something here
    Isn't it right that that ac3 files created by BeSweet and ffmpeg have a compatability problem with Pioneer standalone players ?
    Originally Posted by from the [url=https://www.videohelp.com/tools?tool=92#comments
    BeSweet[/url] page]Other info:
    Besweets AC3 encoder is based on the ffmpeg ac3 encoder and it doesn't create compliant AC3, it doesn't work on some few Pioneer DVD Players.
  10. Member FulciLives's Avatar
    May 2003
    I have an older model Pioneer DVD player and yes I can confirm that they do not like 2.0 AC-3 audio created with BeSweet (though they seem find with 5.1 AC-3 audio created with BeSweet).
    I stopped using BeSweet for AC-3 encoding a long time ago but I understand that the newest version of BeSweet (as well as ffmpeg) no longer have this "bug" anymore.
    Also this problem affected more than Pioneer models I know someone with an older model Samsung that also has (had?) this problem.
  11. Originally Posted by andyp1
    I'm going to buy a dvd writer next week. This is why I asked this question :P
  12. 192 is probably best for me since most of the DVDs I make are from television captures... from over DirecTV and red/white audio and s-video.
    At any rate... I do all of my ac3 encodes using QuEnc in using "No Video" under the mux profile options.
    where bananas go to church...
    ...a monkey will be their preacher
    Dec 2004
    Australia
    Compatibility issues were fixed with liba52 ages ago. Fact remains though that it is not properly tuned for quality. So it won't be as efficient as most other encoders.
    BeSweet, ffmpeg, QuEnc all use liba52 for AC3 encoding.
