2 wks ago, I burned a video I edited in Sony Screenblast onto dvd perfectly using Sonic MyDVD. Now, the same video will not work b/c it is now 68 gigs!!! I can't even shrink it in TMPEG. I'm thinking that I must've changed the compressed setting to uncompressed by accident somewhere? I can't even find that setting to change it back. Can anyone point me in the right direction?
Is it possible you saved it using VirutalDubMod without compression? You need to save it using DirectStream copy and not uncompressed (if, in fact, that is what you did).
What other video related forums do you visit besides videohelp.com?
By johns0 in forum PollsReplies: 30Last Post: 26th Oct 2020, 23:22 -
Common pro video cameras c. 2002 (capturing-related!)
By moxiecat in forum Capturing and VCRReplies: 10Last Post: 13th Jan 2012, 20:04 -
FPS-related problems in Premiere when importing a video (solved)
By quandore in forum EditingReplies: 4Last Post: 4th Nov 2010, 06:04 -
Is this Normal with 6 gigs of memory?
By ineedhelp007 in forum ComputerReplies: 13Last Post: 11th Jan 2008, 17:59
