HI HAVNT USED SVCD2DVD FOR A WHILE BUT HAD TO REINSTALL WINDOWS + SOFTWARE WHEN INSTALLING SVCD2DVD WAS PROMPTED TO INSTALL NEW VERSION DIDNT HAVE MUCH CHOICE IT SEEMED IN THE MATTER CARNT GET THIS NEW VERSION TO WORK.TRYING TO CONVERT TO BIN FILES ABOUT 700MB EACH GOES THROUGH THE WHOLE PROSSESS TILL IT GETS TO MULTIPEXING ELEMENTRY STREAMS THEN NOTHING ELSE HAPPENS THE BLUE THINGY AT THE BOTTOM IS STILL SHOOTING TO THE RIGHT HAND SIDE DOESNT CRASH JUST STOPS I EVEN LEFT IT RUNNING ALL NIGHT(NOTHING).TRIED REINSTALLING TILL I WASIN THE FACE ALSO TRIED ALL OPTIONS IN THE SVCD2DVD OPTIONS MENUE CAN ANYONE HELP HAVE NOTICED OTHER POST WITH SIMILER PROBS BUT NO SOLUTION POSTED.HERES THE LOG.
Starting SVCD2DVD: v1.51.2.0
Begin time: 16:55:10
******** Ripping SVCD images to get mpegs (VcdXRip)
(Total size: 1597MB, Duration: 00:05:07, Rate(MB/Min): 312.12)
Analysing File: C:\Filmstemp\Starsky.&.Hutch.(2004).CD1.TS.SVCD.Vi deoCD.ShareConnector01.mpg
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:00.4a]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:00.4a]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:07.2b]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:02.0a]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0f.08]
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
Error getting mpeg details. (probably due to AC-3 audio)
System.Xml.XmlException: An error occurred while parsing EntityName. Line 1, position 39.
at System.Xml.XmlScanner.ScanNamedEntity()
at System.Xml.XmlTextReader.ExpandLiteral(XmlAttribut eTokenInfo currToken)
at System.Xml.XmlTextReader.SetLiteralValues(XmlAttri buteTokenInfo fld)
at System.Xml.XmlTextReader.SetAttributeValues()
at System.Xml.XmlTextReader.ParseElement()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlValidatingReader.ReadWithCollectText Token()
at System.Xml.XmlValidatingReader.Read()
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at _S_VCD2DVDMPG.210ff09a2516b1a7.b4e369192c57af39(2b c216f3ce925842 a01d771a37e7320b)
Analysing File: C:\Filmstemp\Starsky.&.Hutch.(2004).CD2.TS.SVCD.Vi deoCD.ShareConnector01.mpg
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'backward_I_offset': [00:09.0e]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'backward_I_offset': [00:09.0b]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:09.0b]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.28]
-->Processing 2 mpeg files
############### New MPEG File ###############
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
******** Demultipexing original mpg file
bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
Saving stream 0xE0 into file C:\Filmstemp\Starsky.&.Hutch.(2004).CD1.TS.SVCD.Vi deoCD.ShareConnector01_DVD.mpv...
File C:\Filmstemp\Starsky.&.Hutch.(2004).CD1.TS.SVCD.Vi deoCD.ShareConnector01.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 358022
System headers = 1
Padding Stream packets = 4063, total bytes = 4585159
MPEG Audio stream 0 packets = 34629, total bytes = 79404297
Video stream 0 packets = 323392, total bytes = 735313623
Saving stream 0xC0 into file C:\Filmstemp\Starsky.&.Hutch.(2004).CD1.TS.SVCD.Vi deoCD.ShareConnector01-0.mp2...
Summary:
MPEG Packs = 358022
System headers = 1
(Total size: 793MB, Duration: 00:04:19, Rate(MB/Min): 183.04)
******** Resampling audio from 44.1 KHz to 48 KHz
MPEG Audio Decoder 0.15.0 (beta) - Copyright (C) 2000-2003 Robert Leslie et al.
108560 frames decoded (0:47:15.8), +1.5 dB peak amplitude, 8030 clipped samples
Shibatch sampling rate converter version 1.29
frequency : 44100 -> 48000
attenuation : 0dB
bits per sample : 16 -> 16
nchannels : 2
length : 500244480 bytes, 2835.85 secs
dither type : none
clipping detected : 0.75703dB
Encoding Time 95secs.
(Total size: 75MB, Duration: 00:06:40, Rate(MB/Min): 11.24)
******** Trimming start of video ES
- Nothing to do.
******** Multipexing elementry streams
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File C:\Filmstemp\Starsky.&.Hutch.(2004).CD1.TS.SVCD.Vi deoCD.ShareConnector01_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File C:\Filmstemp\Starsky.&.Hutch.(2004).CD1.TS.SVCD.Vi deoCD.ShareConnector01_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (C:\Filmstemp\Starsky.&.Hutch.(2004).CD1.TS.SVCD.V ideoCD.ShareConnector01_DVD.mpv)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 576
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 2520000 bits/sec
INFO: [mplex] Vbv buffer size : 131072 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (C:\Filmstemp\Starsky.&.Hutch.(2004).CD1.TS.SVCD.V ideoCD.ShareConnector01_DVD.mpa)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : free
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 2559000
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 13019
++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c0!
System.Threading.ThreadAbortException: Thread was being aborted.
at Microsoft.Win32.NativeMethods.WaitForSingleObject( HandleRef handle, Int32 timeout)
at System.Diagnostics.Process.WaitForExit(Int32 milliseconds)
at System.Diagnostics.Process.WaitForExit()
at ProcRunner.c5b4b7804027a156.160a0bf4de8f6bd0(Strin g d168ac2ed64c4662, String a6a477a49a1a2599, String 450f47a9028f884b, a0efedb9fec1e88f 8b49c96cd0348808, Boolean 74effd3a0f44569e)
at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
The problem is the '&' characther in the file path. Change that and you should be ok.
So, Starsky & Hutch is out on DVD already? Still #2 at the movie charts (I can't see how it ever made it there in the first place, but that's me...) over here...
/Mats
Megui encoding stops
By sanosuke in forum Video ConversionReplies: 1Last Post: 20th Dec 2012, 22:36 -
MKV stops
By kcmccombs in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2011, 23:17 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 19:44 -
Video Stops Playing
By DJboutit in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2009, 03:54 -
Burning Stops at about 23% ?
By dagerousdave in forum DVD & Blu-ray WritersReplies: 8Last Post: 20th Aug 2007, 13:29
