  1. My problem is this...
    I have 2 Avi files of diffrent sizes that i need to Resize to be the exact same size...
    one file is 640x480
    and the other is 640x352
    I want to resize both of them to 640x496.
    how do i do this? in the easiest way (least amount of progs to use)
    many thanks
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    Virtualdub, resize filter.
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    load each into virtualdub and use resize filter
  4. new problem...
    every time i try to select the xvid codec to use,and i try to save the avi i get an error like "statsfile not found"
    what does this mean,and how should i fix it...
    all the other avi's that i need to join are xvid's...
    thanks again
