I tried converting my bad boys 2 dvd into divx using dvdx2.2 and divx codec 4.12. The movie is about 2hr 22min long and I tried ripping and encoding it to divx but when the program finished, the movie had only done about 2hr 10 min even though the file said 2 hr 22 min. I used Dr. Divx calculator to find the video bitrate. I guess it had stretched out the 2hr 10min to 2 hr 22min and cut off the end of the movie. I put the output frame rate at 23.976 (ntsc) checked force 24hz. checked audio/video synchronisation and I had to set the audio to 80kb/s in order to make the bitrate go up a bit. I followed every step of one of the guides I found here on this site but don't remember which one. Has anyone else had this problem? Does anyone know how I can fix it? I don't want to try again unless I know it will come out right. Any help would be appreciated it. Thanks for looking.
Results 1 to 1 of 1
dvd m2v time delay problem
By codemaster in forum DVD RippingReplies: 14Last Post: 28th Nov 2010, 21:02 -
HELP: DVD-to-Divx 100% quality, time-splitting... for youtube
By andwan0 in forum DVD RippingReplies: 7Last Post: 9th Sep 2009, 06:50 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 15:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 04:41
